After Effect Crashes after 15min
Greg Burke
on Jul 3, 2019 at 8:03:15 pm
So I'm on the latest version of AE on PC. And after 15min on the dot. the program does a hard crash, even if the project is empty. Any Thoughts? Maybe a clean reinstall in needed?
I wear many hats.
http://www.gregburkepost.com
Greg Burke
Re: After Effect Crashes after 15min
on Jul 3, 2019 at 8:54:57 pm
Update. Did a fresh install. Still crashes every 15min on the dot.
I wear many hats.
Richard Garabedain
on Jul 5, 2019 at 7:01:53 pm
that is a weird problem...do you have any other memory intensive programs that shut down after 15 minutes? is your login info correct? try chaning your password...maybe someone else is using it
Lori Newman
on Jul 8, 2019 at 6:35:29 pm
Just went through the same thing. Only a clean install worked.
