Can you nest Dynamic Link compositions?
Markus Stone
on Jul 3, 2019 at 12:03:30 am
This is more of a workflow question.
If you have project with lots of shots with complex transitions at both the head *and tail, should you;
a) Nest dynamically linked clips in Premiere (I'm not sure this is even possible, but ideal)
b) Construct the project in Premiere to lock-off then replace entire composition with single dynamic link clip (but then you get audio sync issues of you need to massage the timing due to the VFX
c) Construct the entire thing in AE, using AE's sound previews (Not looking forward to trying to get timing and mixing right in the AE interface)
So what do you do when you are trying to construct a project that sits somewhere between an AE and Premiere project?
Cheers
Markus
Walter Soyka
Re: Can you nest Dynamic Link compositions?
on Jul 3, 2019 at 12:32:40 pm
Personally, I'd probably either:
d) Send individual pairs of clips to Ae via Dynamic Link, then use Render and Replace in Pr, or
e) Set it up in Pr, then import the .prproj and finish in Ae.
Walter Soyka
