GreenScreen and hair flicker after using Keylight 1.2
Ryan Johnson
on Jul 1, 2019 at 8:49:30 pm
Having used a DSLR (5d-mark iii) and greenscreen, Keylight 1.2 is just not cutting it. I now know this DSLR is not ideal for green screen. I have flickering hair in my videos (have included one below). Is there any trick to remove flicker around the edges and on areas of the hair with green spill? Even if its overly in-depth, I need a way to do this. Even if using another program or plugin is advised. Thanks ahead of time.
https://drive.google.com/open?id=1Z_s_EmdZGXybdkyFv3VHwcqWJIreOrmA
Simon Ubsdell
Re: GreenScreen and hair flicker after using Keylight 1.2
on Jul 1, 2019 at 10:31:27 pm
The flicker is caused entirely by the noise in your source channels (typically the red when your problem is hair). The only solution is to denoise your footage with something like Neat Video.
Problem noise is pretty much inevitable when shooting with a DSLR.
Simon Ubsdell
hawaiki
Ryan Johnson
on Jul 3, 2019 at 4:24:36 pm
Awesome. You saved my life. thanks! I used the grain in after effects to manually sample the noisy hair and voila. Problem solved.
Simon Ubsdell
on Jul 3, 2019 at 4:55:40 pm
Glad to hear it :)
Simon Ubsdell
hawaiki
