apply unsharp mask to layer without affecting feathered edge
Craig Hood
on Jun 29, 2019 at 8:26:56 am
When I draw a mask round an object and feather the edge, then apply unsharp mask, it also tries to sharpen the feathered edge which screws the edge up.
How can I sharpen everything inside the mask without sharpening the feathered edge?
I want to use unsharp mask and no other sharpening effect.
As a work around I am currently rendering the whole layer as an uncompressed avi with unsharp mask applied, then I'm going to re-import that footage to replace the original, then I will add the mask with the feathered edge.
Kalleheikki Kannisto
Re: apply unsharp mask to layer without affecting feathered edge
on Jun 29, 2019 at 2:47:46 pm
Move the mask to a separate layer and use that layer as a track matte.
Senior Graphic Designer
Craig Hood
on Jun 29, 2019 at 8:18:05 pm
I found out how to do this by either using a track matte as you suggested or by pre composing the layer and having the unsharp mask applied inside that pre composed layer.
Then, back in the main composition, a mask can be applied to the pre composed layer.
I had to do this with three layers and I found the pre composing to be a bit quicker.
