I want to move the vertex of the mark path with an extension already applied.
yh lee
on Jun 26, 2019 at 12:21:00 pm
In case of transform, if I put a transform in the effect, I can edit it twice.
Is that not a mask option?
Walter Soyka
Re: I want to move the vertex of the mark path with an extension already applied.
on Jun 26, 2019 at 5:14:04 pm
I'm sorry, but I don't understand what you're trying to accomplish. What do you ultimately want to do? Can you share any screenshots?
Walter Soyka
Kalleheikki Kannisto
on Jun 27, 2019 at 3:10:17 pm
Do you want o move a mask path point which has an expression applied to it? If so:
If the expression is applied to a null object that controls the point, you can modify the expression by adding "value +" in the beginning. That way the original value will be added to the expression. You may want to start the values at 0.
Or you can use a slider control or point control and add it to the expression (pick-whip the controller value and add a "+" between it and the expression).
If the path is fully built with an expression (rather than via nulls), you won't be able to do this.
Senior Graphic Designer
