Are these specifications correct??
david jones
on Jun 26, 2019 at 8:59:55 am
Hi, I've put together a movie using After Effects and Final Cut pro. The specifications have to be as here shown:
I exported the video out and played it on Quicktime and these are the specifications I saw for my video:
Are my specifications correct? The file is so large that I can't send it to anyone even when compressing it.
Thank you!
Walter Soyka
Re: Are these specifications correct??
on Jun 26, 2019 at 2:53:04 pm
You should double-check the audio specs; some systems cannot handle 24-bit audio.
Everything else looks good. ProRes 422 HQ does require a significant amount of space.
Walter Soyka
david jones
on Jun 26, 2019 at 5:02:58 pm
Thank you, Walter! Much appreciated.
