Remove objects from moving and scaling ground
Stig Olsen
on Jun 24, 2019 at 10:17:26 pm
I have a shot where the camera is pushing in, and it's moving close to the ground. Naturally, the ground elements (grass, stones etc) are scaling bigger when they are closer to the camera. I need to remove some elements from this ground. How would you approach that? ABC please.
Best,
Stig
Tomas Bumbulevičius
Re: Remove objects from moving and scaling ground
on Jun 25, 2019 at 8:27:06 am
Hey Stig,
few things to clarify:
1. How much camera moves?
2. How does environment behind the elements looks like? You mentioned grass, etc. Is there a wind in the shot?
Basically, apart from removing the objects, you will have to 'fill' missing data with the environment. It can be done either by stamping or offsetting masked footage to cover the cleaned areas. Seeing at least a screenshot could help, but ideally - please share whole clip or portion of it.
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer - Dynamic Text Boxes Template with a Live Preview
Kalleheikki Kannisto
on Jun 25, 2019 at 2:20:13 pm
The new content-aware fill does a remarkably good job with this.
https://helpx.adobe.com/fi/after-effects/using/content-aware-fill.html
Senior Graphic Designer
