Is there a way to change the default render setting for channels?
Tilak Patel
on Jun 24, 2019 at 5:47:58 pm
To render an alpha channel, I usually have to click the "RGB + Alpha" dropdown. I was wondering if there was a way to set this to the default as it can get very tedious after some time.
Roei Tzoref
Re: Is there a way to change the default render setting for channels?
on Jun 24, 2019 at 9:51:21 pm
Yes, simply create a output module template.
edit->template->output module. set it as you wish, and set it as a movie default.
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
