A plugin that does what excite from Motion2 does but with more controls.
Nathan Apffel
on Jun 22, 2019 at 7:48:00 pm
Can someone suggest a plugin that does what excite from Motion2 does but with more controls. When ever i use excite on multiple layers i have to go back and manually change the excite expression settings. I wish these could be set before applying the effect.
thanks
Michael Szalapski
Re: A plugin that does what excite from Motion2 does but with more controls.
on Jun 28, 2019 at 5:04:52 pm
DUIK does spring stuff too, but I'm not sure if it has more controls.
What sort of stuff do you find yourself changing? Is it in the expression itself or just to the effect controls?
- The Great Szalam
