How to remove color banding on circle gradient?
Ivan Kychygin
on Jun 20, 2019 at 6:08:28 pm
Hi guys!
Here is screenshot for part of my composition
Does anyone know how to remove color banding on circle gradient?
Doyle Lewis
Re: How to remove color banding on circle gradient?
on Jun 20, 2019 at 7:01:23 pm
Did you set your project to 32 BPC (Bits Per Channel) will increase the number of bits used to create your colors allowing you more steps between your bands. you can change your bpc on the bottom of your project tab.
Doyle Lewis,
Assistant Location Manager
Warner Brother Pictures
Ivan Kychygin
on Jun 20, 2019 at 7:48:38 pm
Thanks for answer!
Yes, I set 32 bpc and it helps a bit.
Also I've added 1% of grain with adjustments layer and gradient become much smoother.
I wonder is there any other techniques instead adding grains to gradient?
Michael Szalapski
on Jun 20, 2019 at 8:14:14 pm
Adding noise or grain is the most common technique. Now, there are many ways to add that variation/dithering that you're looking for. I, personally, like to use either Fractal Noise (with some tweaking on the look) or a stock grunge map (like old paper) very lightly overlaid.
- The Great Szalam
