Create replicable comp
Francesco Benciolini
on Jun 17, 2019 at 11:02:06 am
Hi, i'm having a problem and i struggle even to come up with keywords to search for it:
I'm making a series similar to this one:
I made a little animated face with controllers from joysticks 'n sliders and with arms made in rubber hose, and it works pretty well, now i need to make it as an effect so that when i copy it in a new comp a and animate it without messing the animation in other comps, is it possible? i tried to create a project in after effects and than import that project inthe main one every time i need a new copy, but it messes up the expressions.
as an other way to put it: if i create a motion template file for premiere then if i put multiple copies of it in a timeline every copy has his own parameters, changing them in a new copy will not reflect in already present ones.
i need to do the same with a comp in aftter effects.
To duplicate the comp would be very difficult because it has nested comps and changing the name would break some expressions
Is there a solution i am missing?
Thank you in advance :-)
Post Production Supervisor
Kondoo Video
Milan, Italy
Eric Santiago
Re: Create replicable comp
on Jun 17, 2019 at 1:11:02 pm
It's early in the morning but I'll take a stab at this.
Can you save the file and just re-import each file as a different project?
I do this all the time and this way the nested pre-comps don't get lost.
Michael Szalapski
on Jun 20, 2019 at 9:12:59 pm
It sounds like you need to look into Master Properties. You can have as many instances as you want of your character comp - all with different values for each one!
- The Great Szalam
