Removing Panaromic Distortion
Kalyan Tagore
on Jun 9, 2019 at 11:23:32 am
Hello everyone,
I have a panaromic video (please refer the image link) - which will be projected onto a 360 (four walls) - (plz refer the youtube link)
How can I remove the (spherical) distortion from the 3d renders.
Can anyone please help.
https://www.behance.net/gallery/81337245/Panaroma360-Test?
Kalyan Tagore
Re: Removing Panaromic Distortion
on Jun 9, 2019 at 11:28:57 am
This is the reference video link
Kalleheikki Kannisto
on Jun 9, 2019 at 2:53:28 pm
If the four walls you're projecting onto are close to equal size, you can change the projection from equilateral (as in your original) to cubic projection (6 faces of a cube) in Skybox, omit the top and bottom ("floor" and "ceiling"), then split the four "walls" of the cube into four separate projections.
Senior Graphic Designer
Kalyan Tagore
on Jun 9, 2019 at 6:18:11 pm
Thanks for the reply. The problem is, they are not equidistant... The basic shape of this room is like a cuboid. It's like , 2 walls of 4000px and other 2 walls are 2600px.
The total length of all walls put together would come around 13500px. And the height is 1500px.
on Jun 10, 2019 at 7:36:57 am
My next approach would be to split the panorama into those 4 comps and use optics compensation to remove the distortion. You will need a different amount of the effect on the two differently-sized comps to make the image edges match. I doubt that they will match perfectly, since optics compensation works on both axis, but you have corners in the room anyways.
If you want something that appears more accurate -- i.e. (un)distorts only in one axis direction -- I believe you'll have to use a custom distortion mesh.
on Jun 10, 2019 at 1:39:19 pm
You can use this on the individual walls (on an adjustment layer matching the size of the comp, for instance) and get something quite close to that transform.
13420_equilateraltocubicfaceunwarp.aep.zip
