Expression to assign a color to a letter?
Ari Grunzeweig
on Jun 9, 2019 at 12:47:43 am
I found the following expression on CC to assign a color to letters in a block of text.
However, even though I have the letter 'a' associated with a specific color value, different 'a's in my text and appearing as different colors.
txt = text.sourceText;
switch(txt[textIndex-1]){
case "A":
color = [0,1,0];
break;
case "C":
color = [0,0,1];
break;
case "T":
color = [1,1,0];
break;
case "G":
color = [1,0,0];
break;
default:
color = [0,0,0];
break;
color*100
See attached image.
Any ideas how to ensure each letter is always the same color?
Ari
Kalleheikki Kannisto
Re: Expression to assign a color to a letter?
on Jun 9, 2019 at 3:04:20 pm
How do you have this set up and what property are you applying this expression to?
Senior Graphic Designer
Ari Grunzeweig
on Jun 9, 2019 at 9:26:00 pm
Thanks so much for your reply. Please see the attached screenshot. Does that help clarify?
Thanks gain!
Ari
on Jun 10, 2019 at 3:37:44 am
Ok, I see. That should work, as long as the original color of the type is black. You are adding a percentage of white to each of the RGB channels to the existing color. If the original color is something else, the target color gets added to the original color, resulting in something else.
If you want to use colored lettering to start with, you'll need two color animators with expression selector. The first color expression would add 100% black to any letters that you want to subsequently color. The second would be the same you currently have.
Ari Grunzeweig
on Jun 10, 2019 at 11:48:17 am
Thanks very much, but I'm still not getting the result. My source text is black as is the 'base color' in the expression.
I tried adding an animator before the one I had with color set to black, and the result is the same. This is the full code on the second animator:
case "a":
color = [255,128,0];
break;
case "b":
color = [0,102,0];
break;
case "c":
color = [0,102,102];
break;
case "d":
color = [0,76,153];
break;
case "e":
color = [76,0,153];
break;
case "f":
color = [153,0,153];
break;
case "g":
color = [204,0,102];
break;
case "h":
color = [50,75,75];
break;
case "i":
color = [153,0,0];
break;
case "j":
color = [0,102,0];
break;
case "k":
break;
case "l":
color = [0,76,153];
break;
case "m":
color = [0,153,153];
break;
case "n":
break;
case "o":
break;
case "p":
color = [50,75,75];
break;
case "q":
color = [153,0,0];
break;
case "r":
color = [0,102,0];
break;
case "s":
break;
case "t":
color = [0,76,153];
break;
case "u":
color = [76,0,153];
break;
case "v":
break;
case "w":
break;
case "x":
color = [50,75,75];
break;
case "y":
break;
case "z":
color = [50,75,75];
break;
default:
color = [22,40,69];
break;
color*100/255
Also attached is a new screenshot trying your suggested setup:
Thanks!!
Ari
on Jun 10, 2019 at 1:22:09 pm
Works just fine for me.
Ari Grunzeweig
on Jun 10, 2019 at 1:47:39 pm
Amazing!
I can't figure out what I am doing differently :(
Ari
on Jun 11, 2019 at 4:20:21 am
Here's my file.
13421_colorletters.aep.zip
Ari Grunzeweig
on Jun 12, 2019 at 2:20:55 am
Thank you!
Ari
on Jun 12, 2019 at 6:16:07 am
Did you figure out what the difference was?
