Frame rate issues in my Master composition
Lindsay McCutcheon
on Jun 6, 2019 at 3:23:38 am
I have a 15000x1040 composition filled with 23.976fps animations. I need to scroll from one end to the other in a regular 1920x1040 composition in exactly 10 seconds.
I keyframed the start and end position in a master composition, but as you can imagine the scrolling effect in 23.976fps was way too jarring to see any of the animation clearly.
So I changed the master comp frame rate to 48fps, and the result was much smoother.
My problem is this: I have a metric tonne of masks applied to all of these animations, which are all slipping when viewed in the master comp.
As a work around I tried rendering out the 15000x1040 comp to pull into the master comp (not ideal), but AME crashes every time I try render it.
Any ideas?
Lindsay
