Intersecting 3D Shapes and Text
David Matthew
on Jun 5, 2019 at 10:35:35 am
Hello everyone
Im having a hard time trying to get the intersections between 3D layers. Im trying to replicate a style (link to image attached). It is also seen that the intersection isn't only between the layers, it is also between the text and the plexus in the back. I tried using track mattes, but if there where multiple intersections for one line it would not appear.
Any help would be much appreciated.
-Dave
Image:
https://www.mediafire.com/file/4v0p9yxw3yb77wd/9A99698C-8FAB-4E29-BEC4-B28F...
Kalleheikki Kannisto
Re: Intersecting 3D Shapes and Text
on Jun 5, 2019 at 2:59:07 pm
In that image, you have lines that are on separate layers which are blended in difference mode. They are not actually intersecting on the same layer. The plexus effect is on top of this, not intersecting anything.
Senior Graphic Designer
David Matthew
on Jun 5, 2019 at 8:19:54 pm
Thank you so much ☺ . I was getting worried that I won't be able to get it.
