Mocha Pro Plugin in After effects
Human Najafpoor
on Jun 2, 2019 at 7:26:22 am
Hello everyone
I can't find "mocha pro" plugin in effects & presets panel BUT "Mocha AE CC", so I can't access insert, stabilization, remove or other features of mocha pro. I can't see "Module Renders" in the effect controls when I add mocha pro ae cc. I have mocha pro 2019 full version installed on my computer and I can't access it directly from the effects.
Is there any way to download and install "Mocha Pro" plugin to open it directly just like an effect and also have full features?
Martin Brennand
Re: Mocha Pro Plugin in After effects
on Jun 3, 2019 at 1:16:49 am
Mocha Pro comes in 2 types of product: The plugin and the standalone.
If you have the standalone version installed, it will only work by running it independently as a standalone application (i.e not in a host compositor/editor), but you can export to other applications from Mocha.
The Mocha Pro Adobe plugin is a separate installation that should appear in your effects for both After Effects and Premiere.
Which type of Mocha Pro do you have installed?
Martin Brennand | Product Manager | Mocha - Boris FX (Imagineer Systems)
Human Najafpoor
on Jun 3, 2019 at 5:12:59 am
Thanks. I realized that I have standalone application and I should use Mocha Pro for Adobe. That's really cool.
Human Najafpoor
Mark Whitney
on Jun 4, 2019 at 6:21:44 pm
This might be of interest to you though ...
https://aescripts.com/mochaimport/
Garrett Appleton
on Jun 6, 2019 at 6:50:21 pm
I could be wrong but I thought mocha "pro" has to be used outside of AE. I recall an older thread about this. Again I apologize if this information is out of date. I now use mocha m with 2019 cc unless I need pro out of comp.
https://forums.creativecow.net/docs/forums/post.php?forumid=2&postid=105976...
Garrett Appleton
Motion Design | Compositor | Dev
Apetown Art
Martin Brennand
on Jun 6, 2019 at 10:41:48 pm
Hey Garrett, that is definitely old information. ☺
Mocha Pro has both a plugin version and standalone type since version 5.
Garrett Appleton
on Jun 7, 2019 at 5:30:24 pm
That awesome I am so used to the standalone version I have not even considered the plugin. Good to know thanks.
Garrett Appleton
Apetown Art
