Reverse Path with Bezier Handles
Wouter Dijkstra
on Jun 1, 2019 at 4:19:16 pm
Hi Guys,
Is there a way to reverse a path that uses "BEZIER HANDLES".
I made a nice curve between two keyframes and now want to put the 3rd that should give the same motion back to the first position with the same curve. Just pasting keyframe#1 doesn't do the trick. Time Reversing keyframes neither. The only thing that I'm aware of that would work is the: LoopOut(pingpong) expression. But that would mean the whole layer will start looping and other later adjustments will not work.
I don't want to do it manually šŸ˜‰ I'm looking for a CLEAN look.
Kalleheikki Kannisto
Re: Reverse Path with Bezier Handles
on Jun 2, 2019 at 7:38:49 am
Time reversing keyframes should work. Did you copy both keyframes before time reversing them?
Senior Graphic Designer
Wouter Dijkstra
on Jun 2, 2019 at 7:53:49 am
Hi Kalleheikki!
I tried both ways. I think when I would use 4 keyframes and 1 frame hold it would work like you described. The way I want it is with 3 keyframes only. Like in the screenshot, but I always get a sort of "circle" it never goes back the way it came.
Am I doing it the wrong way?
Wouter Dijkstra
on Jun 2, 2019 at 7:56:03 am
this setup (with a "hold") works. But I don't want 1 frame hold.
Tomas Bumbulevičius
on Jun 4, 2019 at 9:21:42 am
Wouter, looking at first example with 3 keyframes - I wonder - that circular path happens to appear when you paste value of the first keyframe, aka, by trying to reset motion into its original state?
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer - Dynamic Text Boxes Template with a Live Preview
Wouter Dijkstra
on Jun 4, 2019 at 1:48:58 pm
Exactly. So once I put the first keyframe again, the movement becomes (sort of) circular. Adding 4 keyframes (last two "Time Reverse") makes it happen, but it gives one frame hold. I don't want a hold ;-)
on Jun 4, 2019 at 2:32:41 pm
You might be better off editing the motion path in the graph editor to be symmetric. You may need to separate dimensions as well.
