PLEXUS animation logo Flickering issue
emmanuel ganguillet
on May 29, 2019 at 2:33:36 pm
I use an illustrator logo as sprite in a after effect project with Plexus plug in.
Unfortunately The edge of logos are flickering when I use DOF in the camera setting.
Any idea of what I could do ?
E.GANG
Dave LaRonde
Re: PLEXUS animation logo Flickering issue
on May 29, 2019 at 11:21:42 pm
If there are any really thin lines in the logo, that's going to happen and they should be thickened up a bit. I'd only go as thin as 3 pixels, and I'd make it thicker given my own preferences.
Dave LaRonde
Promotion Producer
emmanuel ganguillet
on May 30, 2019 at 5:19:35 am
Hi Dave
There are no lines
Please have a look at the sample animation following this link
https://drive.google.com/file/d/1pVOJQu5K3senQOy4s9kdszVLbSSzgEL8/view?usp=...
emmanuel ganguillet
on May 30, 2019 at 2:21:27 pm
I Think you’re right ! Well its the Space between letters that’s too thin.
But there should be a setup to Fix this !!
Kalleheikki Kannisto
on May 30, 2019 at 3:54:34 pm
That certainly looks terrible. I would try turning on motion blur or using the Force Motion Blur effect. That way you will multiple frames blended together for each frame which might help the situation.
Senior Graphic Designer
