Morphing frames together to salvage laggy footage - (PT Framerestorer)
Hugo Mazzoccoli
on May 27, 2019 at 2:24:02 pm
Hello,
I shot a film on the bmpcc and used an incompatible SD cards (long story short) resulting in laggy footage, with sometimes 1 frame frozen over 1-2 seconds. I want to fix it by morphing the frozen frames together on after effects, and found a script called PT framerestorer that helps me do that.
PT FrameRestorer lets you select markers in your footage and will keep only the frames at the markers and morph during the between times.
However, for the purpose of my film I want to only morph the images where the frames have frozen and keep the frames moving where it's still at 24 fps. Any advice on how I could do that?
Thank you so much
Hugo
