"Shatter" with perspective?
Filip Stillerska
on May 26, 2019 at 5:31:50 pm
I've got an image of a building and I want to make the side of the building shatter/explode. To achieve this effect I'm using the "Shatter" effect. However, the Shatter effect doesn't really allow me to give the shatter any perspective, and the only way to make it seem like the pieces explodes from the side is to rotate the layer in 3D, which doesn't help since it rotates the whole layer including the building... Any ideas?
I want the left side of the building to shatter.
The "Shatter" effect makes it seem like the shattering occurs facing the camera (there's no perspective).
Now the shattering has perspective but the whole layer is also rotated which doesn't look good.
Blaise Douros
Re: "Shatter" with perspective?
on May 28, 2019 at 6:13:43 pm
Watch this. It uses your exact scenario as the tutorial test case.
Filip Stillerska
on May 28, 2019 at 7:02:14 pm
Thank you!
