after effects motion blur render problem?
garcia marie
on May 23, 2019 at 7:33:37 am
Hello,
i have made a project on After Effects CC 2018, and at the end of every keyframe I had made a transition with motion blur. on the preview screen, it looks perfectly normal and the motion blur is where it’s supposed to be, but when I render my project, on the last keyframe of the transition the motion blur completely disappears. I have rendered it multiple times and have even tried to render each comp individually but on ONLY the last keyframe the motion blur still disappears. I have made sure to enable motion blur on the clip and project. I simply don’t know what to do anymore because this has never happened. I would appreciate some help, thank you for your time.
Tomas Bumbulevičius
Re: after effects motion blur render problem?
on May 26, 2019 at 9:02:44 am
Hello Garcia, few things:
1. Do you see motion blur when previewing on that frame in the preview window?
2. Any chance to see a sample of how it looks like and how it should be?
3. Is the last keyframe by any means is the last frame in the project, or this transition/keyframe happens somewhere in the middle?
Cheers.
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer - Dynamic Text Boxes Template with a Live Preview
Oleg Pirogov
on May 26, 2019 at 1:40:14 pm
There is a number of things that can cause this. A detailed description with screenshots would help a lot and providing the project file would be perfect.
