Weird Distortion When Animating Path
Eduardo Ramos
on May 18, 2019 at 9:12:40 pm
Hello,
I'm trying to animate this geometric shape into a circle.
I copied the path property of the circle, and pasted it into the path property of the first shape. However, when it animates, I get this weird distortion. What am I missing here? Thank you in advance.
13353_distortion.mp4.zip
Kalleheikki Kannisto
Re: Weird Distortion When Animating Path
on May 19, 2019 at 7:08:58 am
Most likely you need to make sure that the first vertices of the two paths are in the same direction in relation to the center of the shape.
https://www.provideocoalition.com/after-effects-hidden-gems-set-first-verte...
Senior Graphic Designer
