Stopping the wiggle expression after a few second.
Ruo Zheng
on May 17, 2019 at 9:08:50 pm
Hey everyone,
I just starting learning about expressions and currently, I'm trying to make a flicker-in effect for this logo.
I have wiggle(100,100) in the Opacity property of the logo but I'm trying to stop the flicker after like 5 second into the animation.
What code should I use? I've studied C# before so my first instinct is to make an if statement and turn the wiggle into false statement after a period of time. But since AE expression uses JS so it's different (not to mention all the expression properties). Would an array be better for this?
Andy Zou
Re: Stopping the wiggle expression after a few second.
on May 17, 2019 at 9:41:25 pm
Personally, I'd whip/tie the wiggle function to a Slider, then keyframe the slider from 100 to 0 when you want it. That way you can also "fade" the wiggle using keyframes and avoiding expressions.
Dan Ebberts
on May 18, 2019 at 6:20:05 pm
This should work:
time < 5 ? wiggle(100,100) : value
Dan
