World sea currents in after effects
Filipe Ferrarezi
on May 14, 2019 at 2:23:23 am
Hello Guys!
(Its my first post so i'm sry if I'm doing something wrong! )
I need to create a world map with an animation of the sea currents. Somthing like this:
But I have no idea how to create this effect. I mean, I could hand draw a bunch of mask and animate them, but I was thinking if there would be sort of a procedural way of doing it, or at least from a starting image like this:
If you guys have any idea or experience with this kind of thing, any help would be appreciated!
Thank you!
Cassius Marques
Re: World sea currents in after effects
on May 14, 2019 at 12:49:01 pm
Can't think of anything else but a very calculation intensive particle system. Not complex, but huge.
Cassius Marques
http://www.zapfilmes.com
Filip Vandueren
on May 14, 2019 at 7:59:40 pm
There's apparantly an app on iphone that automates stuff like this.
The closest I've come in AE to a simple solution to this is CC warpomatic set to Warp Direction: Twist
Greg Gesch
on May 15, 2019 at 1:24:42 am
Hi, wow that's a complex job, presuming that it has to be a somewhat accurate depiction of the currents. My only thoughts would be to start with a base image of Fractal Noise (Fractal Type - Strings). Precompose it and then in your main comp keyframe the Liquify effect - mainly the Warp and Twirl tools to create the streams and whirls.
