Puppet pin footage combined with Particular issues
Scott Gaskin
on May 9, 2019 at 6:45:51 pm
Hello,
Please see attached video example. I started with a simple crowd animation of around 7 characters and used the puppet pin to animate these. I made sure each character was pre-comped before I added the puppet pins on advice from another forum. I then used particular to make a full crowd scene but I'm getting this annoying glitch as you'll see in the video. I've emptied my disk cache and cleaned the database, again advised on another forum but still getting the issue. Can anyone please help?
Scott
Max Haller
Re: Puppet pin footage combined with Particular issues
on May 13, 2019 at 4:49:09 pm
Hey it looks like the video didn't actually come through.
Just a shot in the dark though without seeing what's going on- Maybe try rendering the animated people and use the rendered video instead of using the precomps as particles. that would probably bypass what ever is happening to the puppet tool
