Automated speech to text layers in After Effects
Luke Batley
on May 7, 2019 at 8:03:02 pm
Hi
I have a fairly long video I made in after effects that I want to put subtitles on. Now previously I have been adding text layers which is time consuming. Does anyone know of a way to automate the subtitling process or any alternative ways?
Dave LaRonde
Re: Automated speech to text layers in After Effects
on May 7, 2019 at 8:57:34 pm
NO. It doesn't exist.
Adobe tried creating text from speech a few years back in Premiere Pro, but gave it up as a bad job. They haven't pursued it since then.
Dave LaRonde
Promotion Producer
Filip Vandueren
on May 7, 2019 at 9:33:46 pm
The Youtube subtitler tool tries do to a text to speech, you can probably export that data.
ken quemuel
on May 8, 2019 at 2:03:30 am
this may be helpful, it's an expression that changes your text layer based on layer markers - goes inside source text of a text layer.
txt = value;
n = 0;
if (thisComp.marker.numKeys > 0){
n = thisComp.marker.nearestKey(time).index;
if (thisComp.marker.key(n).time > time) n--;
if (n > 0) txt = thisComp.marker.key(n).comment;
txt
in this example, i'm referencing a layer called CASTER01 that has layer markers:
txt = value; n = 0;
if (thisComp.layer("CASTER01").marker.numKeys > 0){
n = thisComp.layer("CASTER01").marker.nearestKey(time).index;
if (thisComp.layer("CASTER01").marker.key(n).time >
time) n--;
if (n > 0) txt = thisComp.layer("CASTER01").marker.key(n).comment; }
txt
Walter Soyka
on May 9, 2019 at 9:27:12 am
You could use a service like Transcriptive to handle the speech-to-text part:
https://digitalanarchy.com/transcribe-video/transcriptive.html
Then use one of Premiere's captions workflows to burn in your captions as subtitles:
https://helpx.adobe.com/premiere-pro/using/working-with-captions.html
Walter Soyka
Wang RuiXin
on May 9, 2019 at 11:28:28 am
Hi there. If you have to put text on after effect. You should creat a new project to manage your text. And In the final COMP. Put the text comp on your final Comp. you need make sure your text comp is longer enough,then you can cut it
But i am always render the text comp and import to PR soft. Unless you only got few more text. In PR it’s very easy to edit the text layer. Hope that can help you.
https://videohive.net/user/untruelife
