Shortcut to Tool Launcher il_list Script
Sascha Koeth
on May 5, 2019 at 3:18:52 pm
Hi! Is there a way to create a keyboard shortcut to open tool launchers tl_list ? I tried to place it in the script folder to access it via the "ExecuteScriptMenuItem" shortcut command line but that doesn't work as the tool launcher script only works in the ScriptUI panel Folder. Any idea? Thanks!
HAYWOOD Digital Studio
http://www.haywood.de
Sascha Koeth
Re: Shortcut to Tool Launcher il_list Script
on May 7, 2019 at 10:57:05 am
Found a first step to the solution:
combine this shortcut modify approach:
https://www.editingcorp.com/after-effects-scripts-keyboard-shortcuts/
keep in mind the path has changed:
/Users/username/Library/Preferences/Adobe/After Effects/16.1/aeks
with
this self-made script in the script folder:
app.executeCommand(app.findMenuCommandId("tl_list.jsxbin"));
BUT!
Does anyone has an idea on how to jump into the search field directly?
