Camera Movement: Keeping camera still and make everything else move (what to do with rotating arm?)
Wouter Dijkstra
on May 5, 2019 at 1:00:32 pm
The arm gives me trouble. I want someone filming himself in the mirror. The arm should move with the camera, but shouldn't move like all the other objects in the room. In the video I try to show my problem. The end shows the result I am looking for.
http://f1.creativecow.net/13321/13321'>13321_cameramovement.mp4.zip
I am looking for a way to first move the Arm/Camera (with keyframes) and than with expressions make it "still" again.
Thanks guys!
Kalleheikki Kannisto
Re: Camera Movement: Keeping camera still and make everything else move (what to do with rotating arm?)
on May 6, 2019 at 6:36:57 am
I would not go the complicated way of first moving the camera and then reversing everything. Just move everything but the camera. Link the arm to the non-moving camera and the bear to it, then the position of the background objects to the bear. Done.
Senior Graphic Designer
on May 6, 2019 at 6:38:58 am
To keep something parented from rotating, subtract the parent's rotation from the child object's rotation.
Wouter Dijkstra
on May 6, 2019 at 1:43:17 pm
Thank you! I go see if it works ☺
I wanted to move the camera first because he is standing in a mirror and it was animated more "naturally". I appreciate helping me out!
