SOS Newer AE file will not open in older version
Isabelle Owen
on May 4, 2019 at 7:47:42 pm
Project created and saved on Version 16.1.1 (Build 4) will not open on Version 15.0.0 (Build 180)??
Tero Ahlfors
Re: SOS Newer AE file will not open in older version
on May 4, 2019 at 7:56:45 pm
Working as intended, however there should be an option to save the project with support to an older version.
Guillaume d'Harcourt
on May 4, 2019 at 8:57:20 pm
That's normal, Adobe is not allowing you do open a project saved on a newer update. However, what you can do is on the new AE, click on "Save as -> Save as CC(14) or Save as CC(13), depending on the update you need.
19 years old french guy, sorry if mistake in my message
