Photos in frames (lots!)
John Nelson
on May 1, 2019 at 5:00:54 pm
Howdy.
Doing a family photo montage in AE CS4. Two picture frames, 70 photos each. My idea was/is having them, the photos, dissolve behind each frame, from one photo to the next. All over a background. This will also be in 3D. Simple enough, I think. But...
Is there some kind of expression (or something else) that could orchestrate this without having to make my fingers numb from typing in the transitions? I know zilch about expressions and failed poorly at algebra, if that is what expressions use...
Gracias in advance!
KEEP ON KEEPIN ON!
Walter Soyka
Re: Photos in frames (lots!)
on May 1, 2019 at 6:14:49 pm
If you build a precomp of all your photos, you can use the Sequence Layers keyframe assistant to lay them all out in time, with overlap and a dissolve:
https://helpx.adobe.com/after-effects/using/selecting-arranging-layers.html...
Walter Soyka
John Nelson
on May 1, 2019 at 10:01:07 pm
Thanks Walter!
You just made my life 'more better'. :}
KEEP ON KEEPIN ON!
