I'm trying to move the texture inside the luma matte but it doesn't work
Nitai Lev-Oren
on Apr 30, 2019 at 7:25:26 am
someone knows why?
Richard Garabedain
Re: I'm trying to move the texture inside the luma matte but it doesn't work
on Apr 30, 2019 at 10:06:08 pm
it is working isnt it? the gold has taken on the shape of the text
Nitai Lev-Oren
on May 1, 2019 at 2:50:42 pm
no. because the texture is bigger and if I move it it doesn't change on the txt
Max Haller
on May 1, 2019 at 8:47:02 pm
Weird it does seem like it's working. Have you tried moving the texture underneath by changing the x,y coordinates in the position property instead of dragging with the mouse?
The only thing i can think of is something is stopping the layer from moving somehow. try moving it through the position property and if that doesn't work try using the transform effect to shift it over.
Nitai Lev-Oren
on May 2, 2019 at 6:31:22 am
I moved it on the X and Y I did it all it doesn't change.
I realized it's because the gold is a Layer style made in photoshop I think it's because of that...
so I do I flatten the layer? (not in photoshop)
Wang RuiXin
on May 2, 2019 at 5:08:10 am
Hi there.
First, you should make sure your text is pure white.
https://videohive.net/user/untruelife
Nitai Lev-Oren
on May 2, 2019 at 6:29:50 am
it's pure white already
