Audio Waveform - that doesn't move from right to left
Martin Gardiner
on Apr 26, 2019 at 3:26:06 pm
Is there a way to just have the audio waves get bigger and smaller, but without it moving from one side of the screen to the other?
Gary Milligan
Re: Audio Waveform - that doesn't move from right to left
on Apr 26, 2019 at 4:35:02 pm
I'm guessing here... I think what you want is to turn off/change the timeline scrolling during playback. This can be changed in your preferences. Change the Timeline Playback Auto Scrolling setting from "smooth scroll" to "page scroll". See attached photo. Hope this helps.
Gary
Gary Milligan
on Apr 26, 2019 at 4:38:22 pm
Oops! Just realized I was talking about Premiere Pro... not After Effects.
Gary
Mark Whitney
on Apr 27, 2019 at 2:18:50 pm
I think what you might be after is expanding the height of an audio row.
On the timeline, if you position your cursor on the bottom edge, I think on the left side where the labels are, it should change so you can drag up & down to change the row height & allowing the waveform to be more visible.
Greg Gesch
on Apr 26, 2019 at 11:20:11 pm
Hi Martin, it's hard to understand what you mean, can you explain what you require in more detail?
Martin Gardiner
on May 2, 2019 at 2:23:17 pm
Sorry, I meant the effect 'audio waveform' - not a timeline feature. I want to apply the effect to a solid and just have the waveforms get bigger and smaller, but not scroll from right to left.
Is there a way to do this?
Kalleheikki Kannisto
on May 2, 2019 at 3:20:27 pm
I think you're looking for something like audio spectrum rather than audio waveform. Audio waves move through time.
Senior Graphic Designer
