Animate Objects Along A Path Dynamically?
Lillian Young
on Apr 24, 2019 at 3:39:32 pm
I have images (pre-comped) rotating in a 3D carousel-style circle. I need to add another image now. How can I do this dynamically so that I don't have to make manual adjustments?
If it requires a script from AE Scripts, I'll buy it. But I just want to know the process.
Kalleheikki Kannisto
Re: Animate Objects Along A Path Dynamically?
on Apr 24, 2019 at 3:49:50 pm
Not that I have watched this, but seems likely the answer is contained herein.
Senior Graphic Designer
Lillian Young
on Apr 24, 2019 at 5:11:00 pm
Thanks for responding so fast, Kalleheikki. I will check that out to see if it works for me. If nothing else, it's a way to go about it based on his sample.
