masked layer not appearing
Paul Norris
on Apr 23, 2019 at 9:40:15 pm
Hi. I have an after effects project that is extremely simple. I have a normal video with no effects and a video that is masked, with also no effects. however, when I play the composition or render the composition, the masked layer does not appear. i have never had this problem, I have scourged my project severely and there is absolutely no reason why it wouldn't work. I am very, very annoyed and frustrated.
Kalleheikki Kannisto
Re: masked layer not appearing
on Apr 24, 2019 at 3:51:54 pm
Make sure you are exporting the right comp. If you have a comp selected in the project panel you may accidentally export that instead of what you see in the comp window.
Senior Graphic Designer
Walter Soyka
on Apr 24, 2019 at 4:03:01 pm
Can you share some screenshots showing the problem and your complete Ae UI?
Walter Soyka
Cassius Marques
on Apr 24, 2019 at 5:41:54 pm
The most common reason is that the layer is set to be a guide layer.
Cassius Marques
http://www.zapfilmes.com
