CC Cylinder Layer Size Issue
Michael Dodge
on Apr 22, 2019 at 6:07:36 pm
Hello All,
Long time lurker, couldn't find a similar thread that was solved with a similar issue at hand so I decided to open this question.
I am having an issue with the CC Cylinder effect. I am animating an Ai file with multiple layers, but am finding an issue when I apply the CC effect to the layer (Fig1).
Fig 1
Fig 2
The mock label that I am looking to animate has a layer size that fits to the artwork with no extra padding. When the effect is applied, the layer size prevents the effect from creating the full perspective effect. (Fig 2)
I would appreciate any suggestions that would solve this issue. I am unaware of how to make the layer size larger, if that would solve this issue. I have also already tried an adjustment layer, but this creates another issue with the "body" of the bottle being below the label.
I am running AE 16.0.1 on a Dell PC. Let me know if further PC specs are required.
Dave LaRonde
Re: CC Cylinder Layer Size Issue
on Apr 22, 2019 at 11:39:36 pm
Just play around with the light in the effect. I think all-ambient light would be a good choice.
Dave LaRonde
Promotion Producer
Kalleheikki Kannisto
on Apr 23, 2019 at 5:36:20 am
For the cut-off issue, you can precomp the layer (leaving all attributes) and then adjust the precomp dimensions to be larger.
Senior Graphic Designer
Michael Dodge
on Apr 23, 2019 at 12:28:26 pm
Kalleheikki,
Thank you! That solved the issue! I only had one Ai layer that needed the effect and was apparently unaware that you could precomp a single layer.
Cheers
