Strange "Repeater" Effect
Gigi Marzo
on Apr 13, 2019 at 7:20:11 pm
Hi...
I'd like to replicate the "effects" of this video (
) at 2':01'' (the tunnel inside the mouth), I wonder: is it possible to do it easily with after effects?
Thank u in advance :)
Kalleheikki Kannisto
Re: Strange "Repeater" Effect
on Apr 14, 2019 at 8:10:26 am
Easily is always a term relative to experience with a given program, but yes, you can do that "easily" in After Effects.
Senior Graphic Designer
Gigi Marzo
on Apr 14, 2019 at 8:19:50 am
Firstly thank u for the answer.
Yep, I know it. 😃 So... I had thought to cut out a picture that could seem like an "internal cavity" of the mouth or throat or something like that and to repeat it... but how? And is the right thought?
(I always write that -this time I have forgot-:the point is that I am a self-taught student)
on Apr 14, 2019 at 3:18:50 pm
You would need a hole for the mouth (mask it) and a layer of the inside of the mouth with a hole in the center, make them 3D layers and stack multiple copies of the inside of the mouth, pushing each back in z space rotating and offsetting each to create the "tunnel".
Then animate your camera to fly through it.
