Content Aware Fill generating blank frames
Chad Ridgeway
on Apr 10, 2019 at 3:19:57 pm
Excited to have this feature in After Effects but after drawing and inverting/subtracting my mask I click "Generate Fill Layer" and it generates a bunch of black, empty frames.
When I try to "create reference frame" I get the following error:
After Effects error: cannot locate an application to open 456.psd
( 1 :: 77 )
Any ideas?
Chad Ridgeway
Re: Content Aware Fill generating blank frames
on Apr 10, 2019 at 3:50:19 pm
Ok even with the error I can still push it through and initial results are shockingly good
https://media.giphy.com/media/RiQ6TsRFvSwSUKKgiV/source.mp4
Dave LaRonde
on Apr 11, 2019 at 5:09:10 pm
I certainly hope you retained a previous AE version that actually worked so you can use it for your serious work until Adobe issues a bug fix for the newest version... or maybe the second bug fix.
Dave LaRonde
Promotion Producer
Max Haller
on Apr 12, 2019 at 8:34:25 pm
wow looks like it worked really well. Did you do anything to fix those frames or it just ended up working?
