Mogrt
Fernanda Perez
Mogrt
on Apr 10, 2019 at 2:12:28 am
Hello,
I'm creating a mogrt in after effects which the shape width is supposed to change size depending on the size of text.
As the text is left aligned, I'm adding the expression to the scale property instead of the size property. However, the shape width is not working very well. The shape is not maintaining the same gap with short and long text.
Both right and left box size should have always the same distance to text.
Any ideas to why this is happening?
Thanks a lot,
fernanda
Kalleheikki Kannisto
Re: Mogrt
on Apr 10, 2019 at 6:47:36 am
What is your expression?
Senior Graphic Designer
