Trying to continuously rasterize - but layer will only collapse transformations...
Chase Langley
on Apr 3, 2019 at 10:49:39 pm
Hi all!
Long time lurker - finally with a big enough thorn in my ass to post.
I have a precomp with a bottom layer that has an alpha and a layer above it set to screen. I'd like to continuously rasterize in order to have the screen work properly in the parent comp - something I know that I've done in the past.
However - when I press the continuously rasterize button - it only toggles the "collapse transforms" setting on.
What's the deal? Is this something new with recent AE iterations? I'm working in CC 2018.... :/
Thanks to anyone who can give me some insight! <3
-Chase
Walter Soyka
Re: Trying to continuously rasterize - but layer will only collapse transformations...
on Apr 4, 2019 at 3:25:44 am
"Continuously rasterize" and "Collapse transformations" share the same switch. It's "continuously rasterize" when you're applying it to a vector layer or a solid, and it's "collapse transformations" when you apply it to a comp layer.
You want to enable collapse transformations for your precomp layer in the containing comp, and if you have any vector/solid layers in the precomp itself, you probably want to enable continuously rasterize for them.
Walter Soyka
Chase Langley
on Apr 4, 2019 at 7:13:24 pm
Hi Walter,
This makes total sense - thank you! I had forgotten that layers within a "collapse transformations" enabled precomp also need the "continuously rasterize" toggle marked.
Thanks again!
-Chase
