Layers move when I precompose
Chrissy P. López
on Mar 31, 2019 at 5:59:36 pm
When I use a Texture in Alpha it gets transparent, and I read that the solution to that is pre-composing the layers. So, I do that and the problem that appears is the following:
The layer moves from its position.
Can someone tell me why?
Thank you very much ♥
Dave LaRonde
Re: Layers move when I precompose
on Mar 31, 2019 at 6:19:52 pm
Looking at the second screen shot, I wonder why a layer called "Paper TEXTURE" would be beneath a layer called "Paper".
I say just straighten thing out in the pre comp and you'll be fine.
Dave LaRonde
Promotion Producer
Chrissy P. López
on Mar 31, 2019 at 6:23:41 pm
The Paper texture is the texture of the layer Paper, and is with Alpha Matte.
Do you I should move the layer in the pre-comp to its original position?
Chrissy P. López
on Mar 31, 2019 at 6:24:51 pm
Do you mean I should move the Layer to its original position in the pre-comp?
Oleg Pirogov
on Apr 1, 2019 at 5:02:38 am
Probably, cause Paper was parented to smth called Hand_L, which was not included to pre-comp, so Paper's position switched to whatever. You would probably want to unparent it before pre-composing.
Chrissy P. López
on Apr 1, 2019 at 10:07:32 am
Thank you!!!♥
