SIMPLE SCRIPT - One purpose button, which adds keyframe with possition 0,0,0
Vojtech Kamas
on Mar 28, 2019 at 12:37:21 pm
I was searching the internet for simple script, better yet plugin with simple fuctionality. My search was unsuccesfull.
Only functions I am looking for:
- Button which makes keyframe at current time
- it is possition keyframe
- it is at [0,0] or [0,0,0]
Do you know about any plugin like this? Or point me at direction which to look at? Or some sipmple tutorial, how taky make one would be also nice!
Best regards Vojtěch.
Thanks for comments and replies.
fb: /krutart
ig: @jorg_krutart
web: http://www.krutart.cz
Max Haller
Re: SIMPLE SCRIPT - One purpose button, which adds keyframe with possition 0,0,0
on Mar 28, 2019 at 3:33:40 pm
I think you should be able to make that as an animation preset. Would that work for you?
Vojtech Kamas
on Mar 29, 2019 at 10:47:15 am
Thank you very much, it work fine.
fb: /krutart
ig: @jorg_krutart
Dave LaRonde
on Mar 28, 2019 at 10:24:10 pm
If you are assuming that 0,0,0 is the exact center of the comp, you are wrong.
The zero z-depth is fine for the center, not for x and y. Zero x and zero y are always the comp's upper-left corner.
Dave LaRonde
Promotion Producer
Vojtech Kamas
on Mar 29, 2019 at 10:48:32 am
thank you for reply!
I know about this, but for my case I wanted the layer to return to parent.
fb: /krutart
ig: @jorg_krutart
