3D object rotation
Jean Tertrain
3D object rotation
on Mar 22, 2019 at 3:08:37 pm
Hello creatives,
How can I make my 3D dolphin object (.C4D) rotate in my AE sequence ?
Whenever I try rotating it, it says : "MAXON CINEMA 4D: Layer size must match Composition and use default transform values".
Thanks a lot,
Jean
Max Haller
Re: 3D object rotation
on Mar 22, 2019 at 4:27:51 pm
You should do the rotation in c4d and save and then it should update in your AE project. When you try to rotate it in AE I think it's just trying to rotate the layer itself not the 3d obj in the scene.
