Count up numbers 1000 at a time.
Darell Nonis
on Mar 21, 2019 at 3:41:49 am
Hi.
I've recently created an AE composition with a text layer that contains a number. My plan is to animate the text so that the number counts up 1000 at a time.
For example, for 3 seconds, I'd like the text to count from 0 to 75000 in 1000 intervals (i.e. 0, 1000, 2000, 3000, ... ,75000).
Anyone's help is much appreciated.
Thanks.
Darell
Dave LaRonde
Re: Count up numbers 1000 at a time.
on Mar 21, 2019 at 3:57:01 am
Over what period of time? Increment by 1000 each frame? What's the frame rate?
A lot we don't know.....
Dave LaRonde
Promotion Producer
Walter Soyka
on Mar 21, 2019 at 8:53:36 am
This expression will do what you describe. Twirl open your text layer in the timeline panel, then twirl open the Text group, then Alt+click the stopwatch for the Source Text property and paste the following:
Math.floor(linear(time, inPoint, inPoint + 3, 1, 75)) + "000"
English translation:
As we progress in time from the layer's in point to 3 seconds after the in point, go from 1 to 75 (linear), drop any decimal points (Math.floor), and tack on three zeroes to the end.
Walter Soyka
