CSV Data Driven Expressions Overtime
Simon Allmark
on Mar 19, 2019 at 6:09:09 pm
Hi, I'm a bit stuck and need your help clever people.
I'm trying to use an expression to show data from a CSV file.
essentially linking the data values of a graph as text as a line scrolls across the graph.
Ideally, I need the individual parameters data changing every frame.
I have imported the CSV and can get this expression to show me the individual parameters if I manually edit the dataValue but I can't seem to work out how I can get it to pull the different data every frame when I play the timeline.
footage("Dinjector out0001 DATA001.csv").dataValue([1,1])
I've tried linking it to a slider that numbers up each frame but no luck and this is a bit more complicated than my knowledge of expressions currently stretches too.
Any ideas on how to do this would be much appreciated.
thanks
Simon
Michael Szalapski
Re: CSV Data Driven Expressions Overtime
on Mar 19, 2019 at 10:49:27 pm
Does putting time into your expression help? That's how I'd count up each frame.
- The Great Szalam
Simon Allmark
on Mar 20, 2019 at 8:23:15 am
Hi Thanks for the suggestion, I tried to use time but I couldn't get it to work, possibly just a syntax error but no luck so far.
I also tried to use a slider to control the Column and Row and the Row counting up but again it's not working, it could be a simple error in my code,
X = thisComp.layer("Expression").effect("Time")("Slider")
Y = thisComp.layer("Expression").effect("Time 2")("Slider")
Value = footage("Dinjector out0001 DATA001.csv").dataValue([X,Y])
my hunt continues!
Walter Soyka
on Mar 20, 2019 at 2:51:36 pm
If you want a new value each frame, try something like this:
footage("Dinjector out0001 DATA001.csv").dataValue([1, timeToFrames(time)+1])
Walter Soyka
Simon Allmark
on Mar 22, 2019 at 8:53:09 am
That's exactly what I needed, works great.
Thanks for your help
