Strange Text Tool Selection Error
Andy Jay
on Mar 19, 2019 at 4:17:35 pm
Hiya,
Ok so I am running AE 2018 & 2019 due to glitches. 2018 Has been my work around.
Today I have opened a build that has been problem free.
When I use the TEXT Tool to select the text (highlight to edit the text), it doesn't work.
It will only create a new empty text layer.
I have uninstalled and tried both versions of AE.
Hopefully I am not missing something obvious, any ideas appreciated.
ps - I am running the previous version of AE due to this kind of error, but now it is happening in both.
Imac / Mojave 10.14.3
Shoots, Animation, Editing. Adobe Creative Suite CC2018. Sound Design & Logic Music Production.
Mac OS X - HIGH SIERRA 10.13.3
iMac 27" F2017 32Gb RAM
BIG SMILES
Dave LaRonde
Re: Strange Text Tool Selection Error
on Mar 19, 2019 at 4:38:48 pm
Does double-clicking on the text layer highlight all the text in the layer?
Dave LaRonde
Promotion Producer
Andy Jay
on Mar 19, 2019 at 5:08:42 pm
Hi Dave,
No that doesn't work, it used to!
I can select the layer with the selection tool .. nut impossible to select the text using TEXT tool.
BIG SMILES
Max Haller
on Mar 20, 2019 at 4:33:13 pm
Not to ask obvious questions, but are you certain there's no hidden/shy layer on top of the text you're trying to select and the text layer isn't locked or controlled with an expression or anything like that . I'm not having any issues with the selecting text myself. If its not working in multiple versions it's gotta be something with the comp.
Andy Jay
on Mar 22, 2019 at 8:08:37 am
Hi Max,
Thanks and good point about the fault happening in both versions.
If I create a new build / comp .. there is no problem ..
So it must be something in the build I was working in.
Managed to patch through it and finalise the project but If I find out what has happened I'll post on here.
Many thanks
A
Mac OS MOJAVE 10.14.3
BIG SMILES
