changing / morphing shapes
Andrew Riss
on Mar 16, 2019 at 5:40:30 pm
this might be simple but i'm drawing a blank
I have a piece of AI / vector art with a bunch of wave forms
step 1- original state
step 2 - it then needs to change shape into a perfect circle
step 3 - it needs to change into a figue 8
thank you in advance!
Andrew
Steve Bentley
Re: changing / morphing shapes
on Mar 17, 2019 at 2:29:49 am
You can paste the copied vector paths into an empty mask (or any mask) at specific keyframes and the shape you paste on that key frame will be the shape the mask morphs to. You can do this all the way down the timeline.
If the paths have a different amount points from each other the paths may "chainsaw" as they change shape.
