Color clamping when rendering
shadow caster
on Mar 12, 2019 at 10:31:15 pm
Hey All,
I'm working in After Effects with a raw EXR sequence in 32 bit color depth. The color space is set to 'none.' When I render the frames that I have worked on (a simple patch and some clone stamping, added noise and used match grain as well as gaussian blur) the colors are clamped--they are flat and not what I'm seeing in my composition viewer.
What could be causing this? Are some of the effects I used not ok for 32 bit depth? If so, is there any workaround to achieve those effects?
Thank you in advance!!
shadow caster
Re: Color clamping when rendering
on Mar 13, 2019 at 1:17:06 am
One more note.....I've been messing with the export settings a bit and now my patches/effects are bright but the rest of the plate is very dull. it inverted somehow...... Cannot figure out this mystery! :)
Michael Szalapski
on Mar 13, 2019 at 3:03:21 pm
Without knowing what your render settings are, it's really hard for anyone to give much in the way of an answer.
- The Great Szalam
