Add repeater to layer, does not rotate correctly
Steve Davies
on Mar 12, 2019 at 12:03:37 pm
I am trying to make a 'flower' shape, and using Add Repeater to the layer, but despite the position being set to 0,0 - the position is off when I add a rotation.
Do you know what I am doing wrong? I have tried to place the repeater in different places in my Group / Contents.
thanks!
Steve
Steve Bentley
Re: Add repeater to layer, does not rotate correctly
on Mar 12, 2019 at 4:58:24 pm
Inside the transform of repeater 1 (not the transform for the group or shapes, I know - couldn't find another name for it?) is an offset which defaults to 100. Change that to 0.
Steve Bentley
on Mar 12, 2019 at 4:59:29 pm
Sorry, didn't finish the thought. The repeater's transform is also where you put the rotation, and not in the "outer" transform.
Max Haller
on Mar 12, 2019 at 9:44:29 pm
you'll probably need to adjust the anchor point in the repeater 1 transform. that's the pivot point which the copies will rotate around. Also adjust the position like Steve recommended.
