Rounded blocky background effect
Ignatz Johnson Higham
on Mar 8, 2019 at 5:23:31 pm
I'm trying to create a background made up of rounded and joined blocks like this image. Could it be done through tweaking a turbulent noise? I really want to get the nice curves between the blocks.
Re: Rounded blocky background effect
on Mar 9, 2019 at 10:46:38 am
Thanks for another pointless comment on the forum Dave. I know this might be expecting a too much from you, but in the future could you elaborate on your responses, flesh them out a little. Turbulent Noise has rather a lot of variables which allows for a large number of outcomes.
Kalleheikki Kannisto
on Mar 9, 2019 at 8:02:20 am
Median filter with large enough a radius over sharp-cornered squares will do that.
Senior Graphic Designer
on Mar 9, 2019 at 10:38:53 am
Perfect. Thank you Kalleheikki Kannisto. Never knew what to use Median for in the past.
