Linked position values don't match up in between compositions
Benjamin Sintemaartensdijk
on Mar 7, 2019 at 10:21:27 pm
Please see the screenshot.
Within the same comp I can convert a 3D layers position to 2D coordinates. That works fine. But I get different values when I apply that same expression to an external 2D null.
What am I missing?
Oleg Pirogov
Re: Linked position values don't match up in between compositions
on Mar 8, 2019 at 12:35:32 am
Does the value varies with time?
Cause expressions are evaluated at their respective comps' times and times on the left and on the right sides are different.
on Mar 8, 2019 at 9:46:18 am
Thank you very much Oleg, that was it. I was hoping it would be a silly mistake like that!
Artist, designer, creative.
http://www.benjamindesign.nl
Walter Soyka
on Mar 8, 2019 at 10:53:04 am
If you have to have some kind of offset in time between the two comps, you can use .valueAtTime() to get the position at a specific time instead of the current time.
Walter Soyka
